cam question
bob the builder
Car  clio 182
hi there,
I run a race car in the tri trophy and my prescent engine has 421 cams with Vernier pulleys (non vvt)
now I have a second engine that I am putting in but it has the dephaser (vvt) 421 cmas but I run omex ecu that doesn't connect to the vvt solenoid .
will it be ok to use without it connected ?
many thanks rob
Surely the omex has a switched output based on revs (the one I had on an itb'd car did). Otherwise I guess you could switch it on all the time.
Sent from my SM-G955F using Tapatalk
it might do but I don't want to mess with how it is now. can it not just be off all the time.
as long as it wont do any damage that's all I'm bothered about.
just being lasy as I don't want to swap it over from the other engine
Surely you want to get the most power out if a race engine?! Pretty simple to wire up. Anyway, will run without VVT, but not as well.
