Cambelt + Exhaust + Service Garage Recommendations
  2004 Clio 182
I bought a 2004 182 a year ago which now has 43k on the clock. I suspect it has never had the cambelt changed so is now overdue.
The exhaust is also sounding a rough / bubbly at idle speeds, which I assume might also need replacing?
I would prefer to replace with standard parts unless there is an advantage?
Can anyone recommend a reliable garage / expert near me. I've recently moved to Leamington Spa so dont know any yet. I could also travel to Birmingham or Coventry.
How much should I be expecting it to cost for both cam and auxiliary belts, new exhaust and a general service?
cheers,
ForceIndia
  Gentlemans spec 200
In your area, has to be btm. Just up the road from you, 1/2 hour drive. One of only 2 people I'd use.
  Disastra Coupe
Neil Harrod Auto Electrical in Mansfield.
My dad works there and they've serviced mine today (cambelt kit, de-phaser, oil and oil filter, air filter etc). Mark's got all the tools for it that are required. If you want to ring them for a quote just PM me for their number :)
  M3 Touring
BTM performance, go down to Birmingham... 30 odd mins from you, the chap is top class!
ForceIndia
  Gentlemans spec 200
That's a 70mile drive, each way??
