cambelt problems (local garages)
loggyboy
because so many garages do f**k it up, either by not using the correct locking tools (the cheap ones are s**t and don't work) or not bothering with locking tools altogether and just muddling through (cos it's only a belt change right?)
If you don't have anything to show it was done by someone who knows what they're doing how can you say it's a decent job??
Your using the exception not the rule to make a case. Simple case is the majority of belt changes are done to a correct standard, its only the horror stories that people cling on to. And besides, one done badly is quite easy to spot, lack of power and torque if done a little badly, obvious bad running if done really badly.
Yes I’m sure many garages do make mistakes when it comes to belt changes on the F4R engine. Who’s to say it hasn’t been done properly though? The engine runs perfectly.
When selling previous Clios 172/182s (or any car for that matter) I’ve never had anyone check which garage has done the belt changes and knock me down if it wasn’t one of the ones they recognised.
I assume my timing belt was done properly as my friend’s tuned Nissan 350z is no quicker than my cup in a straight line:) Even over 100 he couldn’t pull away at all. I know it would eventually go on to a higher top speed though
imprezaworks
  Mk5 Golf GTI :)
On a respectable rollers will soon tell if it’s been done well.
Not that there’s a rollers on every corner but you know what I mean lol
chris blue
  clio rs 220 trophy
I'm Brighton way, so Rentech Portsmouth, or Ren7oaks, both which are fab I am sure, but the prices......
Anyone heard of the "Clioman" littlehampton, west sussex. Will give him a call as he has a good reputation. Apparently his location can be off putting up some sort of farm track?
Ex-User (72296)
  Clio 172
How much does Clioman do it all for? He's very popular on the FB page and he fixed a lot of Clioturbo issues I think.
chris blue
  clio rs 220 trophy
I'll give him a call early next year when mine needs doing, but been told he does full Cam/Aux water pump and dephaser cheaper than most places
Ex-User (72296)
  Clio 172
Fair enough mate. Have you enquired at Rentech? I think he was £650-700 for the full works a couple of years ago.
chris blue
  clio rs 220 trophy
Yes- enquired on here, and he said prices were as he had posted up the year before. Its on here somewhere- as you said around £650 but not sure bout water pump
Edit - Well the Cambelt prices from Rentech were on here, cant find them now. Found a thread that refers to a cambelt price thread, so it may have been removed?
R3k1355
People check for common issues on many different cars, doesn't matter what the issues is, when it becomes known people will look for it.
RS Clio's happen to have a reputation for cambelt stuff.
Just don' understand why Renault in their wisdom, made it such a difficult job in the first place.
Does the Dephaser really do a great deal for performance?
It's not like the VVT systems used by Honda which add an impressive amount of power.
  Westfield, 182, 200
I've just bought a 200 that had a cam belt 2 1/2 years ago by Billy back street :(
I was contemplating getting the belts done, but when I was sorting the dropped door today (had the wheel arch liner out) I noticed the aux belt was cracked! :eek:
So, Fred was the last person who did a cambelt for me, who's now the person to go to near South Birmingham?
I emailed Mick at Diamond, but got no reply :confused:
Ta.
Darren61
Ta.
Chris at BeanieSport in Milton Keynes
  Clio
Is there any way of checking the quality of the cam belt. I have 2 clios, one 2007 (80k miles) and one 2004 (57k miles). I have no evidence whether they have ever been changed or not, and they only cost around £1K so it's not really worth getting them done.
Is there any indications if a cam belt may be about to snap?
loggyboy
Its not about how much they cost, its about how much they are worth. Now admittedly you wont see back what you spend on changing them in value (ie a car with belts due compared to a car thats had belts done recently), but there is massive difference in a car thats running and one thats engine needs replacing.
  Clio 172
What's the current going rate for service with cambelt, dephaser, water pump, aux belt etc?
I can see parts about £850 (kam racing) or £650 in renaultpartsdirect. but then labour will add a decent amount.
Had quote of £1500 from well known renault specialist locally which seems steep!
BashRacing
Last one I did I charged £400 plus vat for the labour only, that was for a full service with belts etc on 172/182,
so maybe a little steep but not a mile off.
Matt Cup
  Iceberg 172 Cup
There's a good video on YouTube by stone automotive I think. Shows the process quite well.
I'll be doing my own I think
Brilliant will check it out.
I’ve got all the bits including genuine Renault locking kit, just no idea 🤷🏻‍♂️
Matt Cup
  Iceberg 172 Cup
That's easy to verify as the keyway in the crank should be in the 2 o'clock position between the webbing/casting marks on the block.
Does a 1#2 have a keyway? I thought that was something that people added along with the Megane keywayed crank pulley? Or am I getting the complete wrong end of the stick and am misinformed?
Mr Trailer Man
Is it worthwhile getting a keyed crank pulley whilst it’s off? Mine looks a bit worse for wear so I might as well replace it.
Assuming you're looking at the dampening crank pulley, the one the aux belt runs off?
Get one if it looks rough.
As for the actual Megane pulley, it's debatable how much protection it actually gives as it's not that strong of a key. It also makes the timing process a little different in the way you even the tension out on the belt.
Matt Cup
  Iceberg 172 Cup
Yeah the rubber on mine is beginning to perish so I presume it’s the original and could do with renewing. I’ll just go for another regular one if it’s not much of an upgrade and makes timing more
complicated.
MRBILLYUK
  FF Jeden Osiem Dwa
I had my 182s full service done a couple of months ago.I supplied everything. Both genuine Renault belt kits, water pump and gasket, thermostat and gasket,type D coolant, NGK spark plugs, Fuchs titan oil and oil filter.
With labour and no VAT I think I paid in total just less than £1100.
That was done at Birchdown.
