CAMBER CORRECTING BOLTS
best throwing the car in for some alignment and they will tell you if it is out and out enough to warrant correcting bolts.
If you want your tyres to last i'd get them 60mm quite a lot to lower by without correcting it
How have you lowered it, is it on coilovers or have you simply fitted springs?
If it's the latter then the standard shocks don't have any camber adjustability.
there just springs! with standard shocks! on abit of a budget at the moment! just want to sort the camber out so i dont scrub through s**t loads of tyres!!!
Well as far as I know (I'll check in a min) the standard suspension has no adjustability.
To be fair 60mm is a massive drop on standard shocks and they will need replacing pretty soon!
Camber correction bolts will work on any front shock set-up including OE. All they do is tilt the hub in/out by using a smaller diameter bolt with a colar at each end. If you have lowered it 60mm i rekon you will need to put some positive camber back on. I use these bolts on my track 172 and havent had a problem. I have a spare set brand new if your interested ?
