camber correction bolts, any need?
I would like to know this also as i have just ordered some FK Highsports for my car.
IF the camber does change you'll be cornering better, dis advantage is that you go through tyres a tad quicker
I'm running stupid negative camber on mine and it corners like its on rails
i was wondering about this myself, want to get an H+R setup. These can be slightly adjusted without the bolts. Supposably This will be absolutely fine/great for road use. When you're going to track her, you'll be wanting the bolts because of the higher degree of camber which you can adjust them with, making it stick like mad.. jippiee!!
