Camber strange happen after damper change
Car  CLIO 172 PH1
When i got my ph1 172, it come with Voland low down spring + orginal damper. When i look from the front, I can see that the camber is " l l "
Last week i replace it by a set of Koni, using the same set of spring , bolt and suspension top. But sth strange happen. I found that the camber of the wheel become " l / " ( I can easily see it got tip) :headno: . The left wheel got correct ( or maybe a little bit negative camber) But the right wheel got positive camber.:cry:
I then uninstall it and setup again. It still got problem. Very strange that after replacement have such large difference. Do a wheel alignment can solve this problem?? It seems more than 2" . Do anyone know what happen can help me...THX
