Can anyone explain this - strange readings
Car  182
I wonder if anyone can explain this (it may be very simple, but currently i cannot fathom an explanation).
Without getting into a debate about what is the best fuel to use, i have been running on Tesco 99ron since i bought the car and consistently getting an average mpg of 28/29 mpg.
However, last month i was running low on fuel and the garage i stopped at didn't do any super unleaded so i filled up with normal.
Now i'm consistently returning readings of 32-34mpg.
How can this be? I thought the high octane stuff was suppose to increase your mpg?
i have exactly the same with my car. when i was using it for a boring motorway commute i swapped to 95 and got better mpg than with v-power. i couldnt figure it out either
You're driving faster because you know you're running on poverty fuel? ;)
Dunno, makes no sense. I reckon my mpg has been slightly better on BP Ultimate 97 than on regular, though remembering to turn the aircon off helped :rolleyes: and the use of the car on two different tanks of fuel is never exactly the same.
Put it this way, I use 95 ron shell petrol, and I return 30mpg in the 197 cup(i don't hang around either) I hear alot of people who use V-Power getting as low as 25mpg up to 27mpg. I saw 27mpg once when Giving it a jolly good run over the mountain.
I would say that i probably do boot it a bit more because for some reason i think if i'm not spending as much then i can use more! :D
But....my mpg should be even lower in that case! not significantly higher! :S
My car doesn't seem to agree with v power. I've always used it since new, but since I've switched to BP Ultimate it runs soo much smoother, before it run terrible when cold.
I fill the megane up with whatever is closest to hand, the magane does a steady 25-26 with my driving, and tend to use 95ron, even on expensive stuff the increase in *performance* is very minimal if not the same - but then driving around milton keynes is all about getting round the roundabouts faster haha
Its definately worth giving them all a bash to see what works best. Seems i might be saving a bit of cash from now on...
mines roughtly the same on each.
ph1 was better on 99 so ive alwys used that in the ph2, however i tried 95 this week and seems to be about the same,
although i tend to ignor my trip computer as its been saying 37.6 mpg lol
It's because Tesco 99 is crap, part bio-fuel, nasty stuff. My 182 ran like a bag of nails when I used it, never again.
i have always run my cars on the tesco 95 and always managed good mpg,
in the clio on the way down to Bath the other weekend i managed 42mpg i was in heaven........
even on the way back i managed 36mpg and i was gunning it to get home so im just happy with the tesco stuff
