len_beach
E92 M3,172 track car
I've worked out why my Clio keeps killing bearings, i'm missing a section of the spacer at the end of the stub axle. See below.
The good side:
The bad side:
As you can see, the central section of this spacer has disappeared so the bearing is around 1/4" further down the stub axle than it needs to be causing serious end float.
Any ideas if you can buy them, what it's called or any other useful info' for my desperate search?
The good side:
The bad side:
