Can i fit a standard 182 zorst on my drive?
  K20 EG Hatch
I have two trolley jacks and axle stands and an uncut standard exhaust.
Can i fit the standard exhaust with these? I mean is it high enough? And am i right in thinking if i undo both the bolt on the bottom of each dampner the back beam will drop making it easier to fit it?
Undoing the bolts will drop the axle down, just get ready to catch your springs ;). I've not tried exhaust fitting (yet) but have done suspension, but I'd imagine anything that gives you more room to work with is good.
  K20 EG Hatch
i fitted my coilovers too it so the exhaust should be straight forward, just hoping there is enough room on the driveway.
As in the haynes manual where the have "out of 5 spanners" as in the difficutly of the job. How many spanners is this job on ur drive lmao?
M
mini-valver
2-3. peice of piss! get it on axle stands and get under, won't know until you try.
