CrashBurnFly
various
Clio 182 - driving normally and then on pops the SERV warning light and car still driving fine. Then lots more warning lights and suddenly it will only tick-over and takes no notice of where the throttle pedal is. Not far from home so gently drive home on tick-over. The on dash errors seem contradictory and I do not have the Renault OEM diagnostics. I checked the connector on the throttle pedal with a meter and that seemed OK. So maybe the other end ... The throttle body insides were slightly gummed up/mucky and cleaned this out and all back to normal and indeed the warm ticker-over now seems higher/closer to where it should be. A thousand miles later and no issues. HTN Paul.
