Car is on kangaroo juice now
Car  R35 GTR
If i hold the throttle position constant the car sometimes, jerks violently on and off the power, this is not the common lumpy idle problem.
It is very dangerous when cornering, i nearly crashed earlier.
Any ideas, back to renault again tomorrow.:mad:
this is the same problem i have, please inform me what the problem is when you find out... mine is mk1 16v tho
james
james
It must be related to the oil leak i had the other day, as I havent had any problems like this before hand.
oil leak?? you been serious mate, surely the lambda sensor has nothing to do with the oil
james
james
Everything has gone wrong since the oil emptied out my engine about a week ago.
Yeah thats it! Take the plugs out, clean them and clean the HT's with WD40 aswell. if oil has gone everywhere it might have got into them causing your big ass misfire. other than that a good caining good solve it.....
it does seem ill, but still rapid ;). So is this violent jerking a misfire? If i plant my foot it disappears, though it is hesitant at first.
Yeah, sounds like a complete misfire i.e no cylinders firing. might even be the TDC sensor covered in oil. check all connections tro wires a clean, spray everything with WD40!!
I think it was something to do with the non existent chip that wasnt fitted to my car, removing this non existent chip seemed to leave the MAP sensor unconnected.
All seems fine now.
