Car starting Troubles..
Car  ATS CUP'd Dynamique
Today i tried to start my car...
I turned the key and all the lights appeared on the dash as usual but nothing happened, the engine didn't start and it was like i just turned on the ignition.....
I had to do this 3-4 times before the engine started
what could this be ??????
Its a problem with a key or the transponder ring around where the keys goes not recinving the signal.
Sounds most likly its the transponder rign if it happenes any more you need a new ring or check the wires on the back of them there eas to change and a common problem.
