Cat list two cams for the F4R in 422 spec.
One keeps the VVT and one looses it.
Could I just rid of the VVT pulley and fit a exhaust pulley in its place? Or if you removed the VVT would you need to play with timing outside of the standard position?
info
clearance [cl] 0.00mm 0.00mm
duration [0.1mm+cl] 284° 276°
duration [1.0mm+cl] 247° 239°
valve lift [cl=0] 11.25mm 11.25mm
cam lift 5.70mm 5.70mm
peak angle 104° 104° followers: O.E.M.
timing [1.0mm+cl] 20/47° 43/16° retainers: O.E.M.
lift at TDC [cl=0] 3.40mm 2.85mm springs: PAC-E99862
information & important remarks:
# ! [link] spring info for Renault Clio 2.0L 16v RS
# to use double spring [ref.PAC-D92009] on retainer [ref. 99388]:
remove O.E.M. valve seal and use flat shim to adjust fitted spring length
# The original intake camshaft is equipped with a VVT (vanos) system. Catcams can supply this camshaft
1/ for use with VVT system (similar to original intake camshaft)
-> 55024xx (hydro) / 55025xx (mech)
2/ for use without VVT system an adjustable pulley ref. CTRE006 (similar to exhaust camshaft)
-> 55034xx (hydro) / 55035xx (mech)
IMPORTANT:
- the timing data are shown for use without VVT system and fixed pulley
- when ordering, please indicate the type of intake cam you need by using the correct partnumber code
# ONLY for use in race engines with adjustable engine management or carburettors.
info
IMPORTANT:
