CDA-9853R - CD/MP3 and sub???
  BMW 125i
i just fitted a vibe space 12" sub last night but have the remote wire coming from the amp to the battery! but cause of this i have discovered that the sub gives out a 'popping' noise when the ignition is turned on, i have been told this in time will flatten my battery and also the 'popping' noise gets on my nerves!!! So does anybody have a clue where to wire the remote cable to the CDA-9853R - CD/MP3 head unit, please asap!!!! :)
muz
  big fat japanese bus
the loom has a blue and white wire, you might need to snip it and connect suing a block connector or bullets then heatshrink.
you can then run the cable to the amp through the car. You don't need huge cable as it is only carrying a signal.
  BMW 125i
i take it i will have to cut this then wire the remote wire from the amp to this and everything should work??? as some guy was trying to charge me £35 to do this told him where to go, but im not very good with electronics!!! :eek:
  Golf GTi Mk2
Its not rocket science son, there should be a blue wire with white stripes on it coming out the back of your head unit, get a length of wire, attach it to this blue wire and then run it to your amp, attach it to the 'remote' terminal on your amp, et voila, power.
