ceebot4---HelPPP
Car  Honda Civic 2.0 TypeR
basicly i use ceebot4 (programming program) and i was wondering if anyone has the code for project 1 would be very helpfullllllllllllllllllllll :) thankyou this is what i got but when i try and run it says there is a problem (which ive marked below in yellow) if i get rid of it says there is a problem with the labyrinth (marked green)
anyone help?
extern void object::Labyrinth ()
int choice;
do
choice=Menu();
if (choice == 5)
Quit();
break;
Action(choice);
}while (true);
//*****Prints a message on top of the screen. After a few //seconds, the message disappears automatically.
//Put in the brackets the messge to be displayed:********
//***********menu_here************************
int object::Menu()
message ("1 - Move Forward" + " 2 -Move Backward");
message ("3 - Turn Left" + " 4 - turn Right");
message ("5 - Quit");
do
string input = dialog ("what's your choice?");
int choice = strval (input);
if (choice==1||choice==2||choice==3||choice==4||choice==5)
return choice;
else
message("invalid input!");
}while (true);
//************action_here*********************
void object::Action(int choice)
float num;
num=getNum("How much do you want to turn/move?");
if(choice==1)
move(num);
else if(choice==2)
move(-num);
else if(choice==3)
turn (num);
else if(choice==4)
turn (-num);
//***********getNum_here*********************
float object:: getNum (string prompt)
string input;
float number;
input = dialog(prompt);
number = strval(input);
return number;
//********quit*************
void object::Quit()
message ("Goodbye");
object item = radar (GoalArea);
float dist = distance (item.position, this.position);
message ("You are still " +dist+ " metres away from the GoalArea");
//float number;
//float average;
//int count =0;
//string input;
//int messege;
//turn (180);
//move (10);
//input = dialog("what do you want to do?");
//number = strval (input);
PROJECT
float totaldist = 0;
float turns = 0;
int choice;
do
choice=Menu();
if (choice == 5)
Quit();
break;
else if (choice == 1||choice==2)
totaldist += Action(choice);
else if (choice == 3||choice==4)
turns += Action(choice);
else if (choice == 6)
Stats (totaldist, turns);
}while (true);
int object::Menu()
do
return choice;
else
}while (true);
float object::Action(int choice)
float num;
if(choice==1)
move(num);
else if(choice==2)
move(-num);
else if(choice==3)
turn (num);
else if(choice==4)
turn (-num);
return num;
string input;
float number;
return number;
void object::Quit()
//***************statistics*****************
void object::Stats(float totaldist, float turns)
message ("the total distance is " + totaldist);
message ("the number of is " + totaldist);
message ("The time taken in seconds taken so far");
//float number;
//float average;
//int count =0;
//string input;
//int messege;
//turn (180);
//move (10);
