Center cap
  197 black 57 plate
Can someone please help with the size Center cap I need to order as 1 has gone missing , I've got a 197 with standard multi spoke 17" wheels ?
Thank you
Measured the bore as there are 2 and the smaller one is 52mm and larger is 56mm but can only find 57mm caps on eBay , are these the ones ?
I'm not paying £20 to steelers for 1
Slightly confused. Are you measuring the hole in the centre of the wheel or the hub? The wheel centre bore is definitely 60.1mm.
If you're looking for something to cover the hub nut and thread I'm sure eBay breakers will post you one for a pittance.
