Changing AUX belt
My AUX belt will need changing in the not too distant future and I'm wandering if this is a job for a specialist or would any capable mechanic be able to do the job?
I called my local dealer and they quoted £388 for supplying the part and fitting! Needless to ask I thought I'd ask on here before booking it in..
Dex90
  11Megne250/02Clio172
Any mechanic. Requires no timing or anything. Change a tensioners, pulley and belt. Parts are £110 ish and would take an hour - hour and a half. Certainly not £300
Sent from my Moto G (5) Plus using Tapatalk
Which Clio model is it? The 172 cup is a doddle to change the aux belt on (10 mins compared with several hours for the models with AC).
Definitely get the cambelt done at the same time
Dex90- thanks for the reply.
Mavez- my thoughts exactly!!
JamesBryan- my cambelt was done at the same time as the Aux belt along with the water pump a couple of years ago so I'll get it change when it is next due with the cambelt at the same time.
Cup172Rich- it's a FF182.
Cheers all for the responses it's put my mind at rest somewhat after the initial shock of the Renault quote!
