Hi Guys,
I’m going to be changing the front calipers tomorrow as upon inspection, the rubber seals have perished on around the pistons.
I’ve got everything stripped back to change the discs / pads at the same time and new RBF to bleed through once conplete.
My question is, how am I best to take the old caliper off and fit the new without losing all of the fluid in the lines.
I’ve read about the pump needing to be sorted with clip of it does run dry so want to avoid this at all costs.
To note, I have braided lines if this makes a difference to any advice you may have.
Any tips/tricks are welcomed so this can go as smoothly as possible.
Also changing rear discs and pads at the same time so will be a full brake system refresh.
The retaining clips on the rear pads I am not looking forward to as these seem tricky?
