Changing MK3 sidelights
Hi,
Is changing the MK3 sidelights a bumper off job? Got the projector headlights fitted but not sure how to go about changing the sidelights. Also, what kind of sidelight LED bulbs would you recommend? Got some 1W LED ones at the moment but not fitted, not sure if these would be bright enough?
Finally, for the silver indicator bulbs everyone uses is it better to get the proper Phillips silvervisions, or would something like this be the same:
http://www.ebay.co.uk/itm/CHROME-SI...odel:Clio|Plat_Gen:MK+III&hash=item1e822c0cb4
ive got a mk3 facelift and I know that on mine you shouldn't need to remove bumper to change the bulbs but it is a bit fiddly!
It's been covered on here so many times but you don't need to remove the bumper to change the headlight bulbs. You just need someone with tiny hands to do it for you! lol ... The drivers side is not 'too' bad but the passenger side is worse - I remove the plastic parts around the battery box and it gives you a bit more room. You should be able to do it without removing the bumper
Ah thanks :) can anyone recommend some white sidelights for me? Am I right in thinking these are also on sligently with the headlights?
