changing top engine mount
wouldnt of thought so im guessing you have to support the engine from underneath and just take the old one off
Undertray Off,
Jack up engine on the sump (use a block of wood between the jack and sump)so its supporting the engine,
Remove old mount,
Fit new mount,
Remove jack,
Replace under tray,
Job done!!
Yeah sorry forgot about the engine cover! The undertray is the black plastic cover underneath the car that protects the sump etc
the undertray, if fitted, is the plastic tray bolted to the underside of the subframe. engine cover would have to come off, too
you're just taking the weight of the engine with the jack - not lifting it too much
you might find it takes some effort to 'crack' the nuts that bolt the alloy casing to the cylinder head; other than that, fairly straight forward
