Checking abs rings
Car  Ph2 Meg 225
Just a quick one, I have the brake pedal fart as it seems to be named on here and would like to have a look at the suspected abs rings to see if they are the problem.
Where are they located? Can I jack the car up to be able to see them or does it need the wheel, discs removing?
put it on full lock and you can feel the fronts at the back of the hub on the driveshaft-its near enough touching the hub
when mine started farting the ring spun freely with a gentle poke it was obvious which was at fault
