Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Is there any key places where the gas usually leaks? Mine went from working well to the compressor not even clicking on the next time I tries to use it, so I'm assuming there's a major leak.
Leaks are normally found in the exchanger unit seals and the exchanger itself due to strike damage. Not necessarily a leak though... System integrity could be 100% and so holding pressure just fine but isn't working due to a component failure such as the relay or even something as daft as the pressure sensor. The only way you're going to know for sure is diagnostics/live data on that system or go somewhere like "Kwik-Fit" and have them pump the system with a leak detector (Which will cost you) and they'll then send you on your way for a day or three so it can do its thing and leave a nice green mark on everything should there be an actual leak.
Any garage that does air-con re fill's/re-gas will do it realy it is a bright green/yellow die put into the system as said above we sell quite a lot through work
Just got the seals on my compressor replaced today - mine was regassed first week in June and noticed last week it wasn't cooling the air at all as the compressor wouldn't kick-in (you normally hear a clunk or a change in engine tone)
£162 at Renault to replace the seals that were split and check & regas the system again. I was freezing on the way home
