Clio 03, Passenger seat eletrics faulty, help?
Car  Renault Clio Dynamique 03
I started off having indiactor problems not working and sparking in and out, now my lights are sparking and not working properly when driving and cutting in and out, and the passenger seat box thing, is making a horrible sparking eletric sound when moving in motion.
I got this fixed at a garage, which was down to a faulty wire, but now its happening again, where can i get this wire and how do i fix this?
After fiddling around with the wire again this morning, I found that the connection actually fits in quiet securely. However when the lights spark out or are sparking, if the connection is tapped or pressed it sorts the lights out.
Could this mean that the problem is with actual wiring of the socket, as there looks to be lots of wires going into the socket ( As Pictured )
Anyway, here are some pictures of the area of the problem and the socket and wiring.
