Heya everyone.
I have a Y Reg 1.2 Clio sport 16v that I bought 1 year ago and it has been running lovely. Then one day last week I went to go to work and it wasn't right.
Most of you probably know what I mean when I say it's running lumpy, but to explain what it feels like would be similar to if you was to try and pull away in 3rd gear.
It's really shaking whan you just sit in it whilst its running and is really lumpy in 4th and 5th gears especially. Also it has got no go in it, loss of power when trying to speed up.
I'm not very mechanically minded but I was told that it would probably be the Coil Pack. So I ordered a new one and It arrived yesterday. It's one that has the leads already in it. I also got 4 new spark plugs for it aswell. I got a family friend to fit it for me, tried it out and its still the same
If anyone has any advice and suggestions about this, I'd be very grateful.
[TABLE="width: 400"]
[TR]
[TD="width: 5"]
[/TD]
[TD]
[/TD]
[TD="width: 6"]
[/TD]
[/TR]
[TR]
[TD="width: 5"]
[/TD]
[TD="class: forumbox"]
[TABLE="class: alt1, width: 100%"]
[TR]
[TD="class: tcat, colspan: 2, align: left"]Ignition Coils [/TD]
[/TR]
[TR]
[TD]
[/TD]
[TD="align: left"]
Ignition Coils
An ignition coil (also called
a spark coil) is an induction coil in an automobile's ignition system which
transforms a storage battery's 12 volts to the thousands of volts needed to
spark the spark plugs.
This specific form of the autotransformer,
together with the contact breaker, converts low voltage from a battery into the
high voltage required by spark plugs in an internal combustion engine.
In
older vehicles a single (large) coil would serve all the spark plugs via the
ignition distributor.
In modern systems, the distributor is omitted and
ignition is instead electronically controlled. Much smaller coils are used with
one coil for each spark plug or one coil serving two spark plugs (so two coils
in a four-cylinder car). These coils may be remote-mounted or they may be placed
on top of the spark plug (coil-on-plug or Direct Ignition). Where one coil
serves two spark plugs (in two cylinders), it is through the "wasted spark"
system. In this arrangement the coil generates two sparks per cycle to both the
cylinders. The fuel in the cylinder that is nearing the end of its compression
stroke is ignited, whereas the spark in its companion that is nearing the end of
its exhaust stroke has no effect. The wasted spark system is more reliable than
a single coil system with a distributor and cheaper than
coil-on-plug.
Where the coils are remote mounted they may all be
contained in a single moulded block with multiple high-tension terminals. This
is commonly called a coil-pack.
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD="width: 6"]
[/TD]
[/TR]
[TR]
[TD="width: 5"]
[/TD]
[TD]
[/TD]
[TD="width: 6"]
[/TD]
[/TR]
[/TABLE]
[TR]
[TD="width: 5"]
[TD]
[TD="width: 6"]
[/TR]
[TR]
[TD="width: 5"]
[TR]
[/TR]
[TR]
[TD]
[TD="align: left"]
Ignition Coils
In
coil-on-plug.
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD="width: 6"]
[/TR]
[TR]
[TD="width: 5"]
[TD]
[TD="width: 6"]
[/TR]
[/TABLE]
