I'm having a slight confusing problem with my Clio. It's slightly odd. The car runs at normal temperature, doesn't lose coolant and drives perfectly normally (usually) and always starts on the button. However, the oil filler cap is full of mayonnaise, the heaters blow warm/ but not hot. and the coolant bottle never gets hot.. ever, at maximum it only gets slightly warm. When cold the car is also a bit lumpy and boppy (exactly the same symptoms as the lambda sensor problem, so unsure whether that problem is related?) Any suggestions? I'm a bit lost i must be honest. Thanks Steve. |
