Mk3 clio 1.5
				Hi all, So I have a 2006 1.5 dci 103k on clock, this has worked and never failed since i bought it 6 month ago.
First issue i had when i took it to a car wash and left engine running whilst the rollers went round, after then a mesage popped up saying check igntion and the turbo didnt kick in, futher down the road the water must of come out as it kicked up working fine again. 3/4 month later on way home, car starting splutering and spanner icon appeared with check ignition, power suddenly dropped and felt abit like limp mode, i noticiede a cloud of white smoke appear from the back, i was so close to being home so i drove it slow till about 1mile away, i started hearing a loud clanging like pistons without oil, it cut out and was left with the error of check ignition. I know have it home, day later when plugged into ecu it read no errors and ignition warning has gone. You try starting it which it turns over and almost starts. I dont hear the fuel pump priming anymore, theres fuel in the tube and manual pump is solid.
Any suggestions here?
