Clio 1.6 Engine Mounts
Car  1.6 Clio
Hi all,
I'm getting a Loud tapping noise when letting off and changing in anything higher than first gear. I've worked out its an engine mount because if I rock the engine with my hands the noise comes from the right engine mount below the battery. My problem is there's an upper and lower gearbox mount :S is the lower gearbox mount the dog bone mount or is it something completely separate??? http://www.eurocarparts.com/mobile/...c54d06caa1914680b6b8828949be6a0c3d8bbc&000461
This is the mount I thought I needed but I'm not sure now?
Anyone got any ideas?? :)
Hi all,
Lower mount is the dogbone mount iirc. I heard the symptoms of that needing changing are if the gearstick wobbles when going on and off the accelerator.
you will have 3 mounts on your 1.6 engine mount gearbox mount and dog bone mount.
the one in the eurocarparts link is the engine mount cambelt side.
normally movement in the gearstick is from a worn dogbone mount.
