clio 16v Brakes options
Car  ph1 172
I keep trashing standard pads so i need a recomendation on some fast road pads. I'd like a nice aggressive bite from cold. but also im really really skint at the moment so the cheaper the better
Another option is to put some wilwood 4 pots that ive found on a scrapped car.
Does any body know whether there is a wilwood adaptor for the clio mk1?
And what discs would i end up using?
im guessing i might need some new brake lines too
DS2500's are fine realy
There no Willwood adapter for sale best ask on Williams Clo as someone was arranging a group buy and had drawn the bracket up agaian. Its not difficult to work pout how big you need it anyway just get the measuring tools out then draw it up and get a machine show to make the bracket up its just a piece of metal with 4 holes and a step in it.
You want to ensure your Willwoods you've found have the correct sized pistons
Disk well you cna use stock there fine or 172/182 ones but there heavier so no need realy plus more expensive. New lines you can order from Goodridge etc
well the car is due to be scrapped and they will need rebuilding so im sure i can get them for not very much money. even if i dont put them on my car i might ge tthem, rebuild them and then sell them
