Clio 172 brake effort values
scotiamr2t
Car  Mazda 2, Ph1 172
Looking to find out what values people have typically seen in the MOT brake test for a 172 cup?
Preferably in KGF although I can convert to KN if need be.
cup should be pretty much the same or near as damn it to a non cup. what did it pull on the rollers?
hydraulic handbrake?
Nope standard handbrake. Do you have typical values or a print out of a clio so I can compare?
Literally every part of the braking system is new. So I need ballpark figures to work from
nothing at home but that figure isn't bad, i wouldn't worry about it. what's causing you concern? just the figure or how it actually brakes when you're driving it?
a bit of both. Figures are lower than I would have expected, also under braking it pulls left although when I stuck it on the brake tester there was an imbalance across the front which I am in the process of resolving.
@bloke the brakes are plumbed in as per this diagram
@JamesBryan helpful yes as it tells me that they read lower than a 182. What do your fronts do?
Also interested as to what values a cup typically produces.
