clio 172
Ive started getting my Engine ready for removal bearing in mind i havent done it before and trying to follow guides on here to assist me.
Ive removed the majority of things rad, lights cross memeber alternator air con etc.
Havent removed driveshafts until i have bought an engine lift !
Disconnected and removed ecu, disconeccted the sensors from front of block, unplugged the white block connector in fuse box and removed the fuse box from the bay but just have the relays all connecet, can these be split from each other ?
Ideally i would like to get the wiring loom out of the engine bay but unsure what i need to do next as i cant see behind the back of the block to see where the loom goes too ?
I just have a wiring loom gathered ontop of gearbox which goes behind manifold so im unsure if i can actually disconnect all of the wiring loom and remove it from the engine bay ?
Going to look where i can buy an engine lift the cheapest, probably thinking ebay
any advice or help would be great
