CLIO 172 GEAR SPEEDS
I am waiting for an RS Tuner'd Ecu from Henk @Fastchip.
What would i get in each gear with that fitted ?
  Cupra 300 ST 4drive
a little more in 1st to 4th but nothing in 5th as you need more power to push the air out of the way to go any faster.
  Ph1
LOL
What does the RS Tuner raise the limiter to ??
Im running a pmurray ecu map with raised limiter to 7800 and it'll pull 70 in 2nd for example. Dont often take it to the rev limit area unless im on the quarter
  Monaco Ph2 172
Am I being thick in saying that if you don't raise the limiter, then you are still going to get the same maximum in each gear?
from search:
172
5.3 mph/thousand rpm
8.7 mph/thousand rpm
12.3 mph/thousand rpm
15.8 mph/thousand rpm
20.4 mph/thousand rpm
  Clio 172 Phase 1
Wasn't there a difference between the phase 1 and phase 2 models?
Because my gears are longer then the above posted values.
In KPH:
1st ~ 60
2nd ~105
3rd ~ 150
4th ~ 190
5th till it stops
3950rpm @ 140 --> ~ 245
in MPH:
38
65
94
118
153
THis is for a phase 1 172 :)
  VaVa
The gears are longer in the ph1. They were shortened in the Ph2 to counter the extra weight. Ph1's are still 4000000 times quicker though apparently.
JMR
  RB 182 Cup
1st - 45mph
2nd - 70mph
3rd - 100mph
4th - 125mph
5th - 145mph
:cool:
RS Tuning remap, cat back 2" Powerflow, ITG Panel. Limiter raised to 7650rpm.
'03 172.
  '92 172, Lotus Elise
based on a 7000 limiter and 195 50 15 tyres,
Mph/1000rpm - Max. speed
5.64 - 40
9.36 - 66
13.20 - 92
16.95 - 119
21.95 - 154
that's from my calculations based on the Renault workshop manual for gearboxes (JC5 089, so ph1 172)
  182, SQ7, Trafic
Ph1 172 with K&N and Cat-Back powerflow
1 - 42
2 - 68
3 - 100
4 - 120
5 - Unknown!!
