clio 172 ph2 trouble starting
Car  172 Ph2/Mgb GT/T4
i recently purchased a 172 51 plate and since getting it home ive had trouble starting it when i try the imobilser is very temperamental but when it doesnt interfere with starting it usually turn over 3 or 4 times then just stops then will randomly start at other times though never 1st time then when i had it running earlier i turned it off tried to start it again and it started 1st go so maybe needs to be warm any ideas would be appreciated
many thanks
Im haveing the same problem sometimes i just push the reset switch and it works, I would love to know the actual solution.
kind regards
Jonny
