182 Trophy, Octavia vRS
Okay,
So me and some friends were fitting the Maxogen induction kit and had to stop part way through as it was getting a bit dark and we need a smaller socket tool which we didn't have.
The problem I have is the bonnet refuses to now open after it was closed. I let it shut as normal then went to open it with the passenger side lever, this felt totally slack with no tension..... you can also just about pull the release catch at the front but this does nothing. Tried pulling both the release and the lever inside at the same time... tried trying to push the bonnet shut further, tried pulling everything but it won't budge
The other problem is as the battery is not connected and the or the air filter I can't even move the car anywhere so i'm totally stuck, any ideas please
Many thanks,
Andy
Many thanks,
Andy
