Clio 182 Turbo
I've not done anything for a few weeks. Still need to sort the alternator bolt and get the sump back on etc but go on holiday next week so it can all wait.
I'm after a couple of recommendations. I need a clutch so any suggestions on that? It's still cable clutch and too much effort to swap to hydraulic so would prefer something that I don't need quads like Arnie to use.
I'm also going to swap the coolant hoses for black silicone ones as they all look a bit tired. There are literally hundreds of results come up. Has anyone used a set that have been decent or do I just pick a random set and go with it?
Mtc hoses are ok. Run them on my trophy.
Thanks! Had some eBay balance so a set worked out at just over 9 quid delivered 👍
I have the paddle version on mine, great on track, not so great on the road although it is useable.
Its heavy still but its more of an on/off engagement.
Once its engaged and you are rolling its fine but setting off can be interesting sometimes.
Cheers. See... the problem I have is my drive is on a hill. All my cars are auto now and I'm not convinced I'd get it off the drive without looking stalling 20 times and looking like a total dick 🤣. Also says it's rated to 350NM of torque and I think I'll end up beyond that even just on the EFI boost control module on the high boost setup.
First bit of Clio work for what seems like ages.
The new alternator isn’t threaded like the old one so got that on with a bit of threaded bar chopped to length.
Fitted and torqued the crank pulley. Took a bit of imagination on stopping the engine turning over, hence engine upside down.
Then I went to put the belt on and the b*****d tensioner snapped. The new alternator doesn’t have as much swing as the old one so couldn’t even bodge it. With that done I went in the house in the huff and sacked it off.
Once I’d calmed down I had a look at the tensioner and there is some back and forwards play (to and away from the engine) even though it’s torqued. Not sure if I’m missing a washer or something. Either way, new one ordered and I’ll try again later 🤦‍♂️
Clutch wise I’ve found a few options.
This one to 330lb/ft
Or this one to 300lb/ft
Both are paddle which I didn’t really want but not sure I’ve got another option. Would a swap to hydraulic clutch at this point make it a bit more liveable? I know it’s going to be a bit of a ball ache when stop/start but if going hydraulic makes it a bit lighter I might go with it and swap to hydraulic.
Me and a mate both have sachs paddle clutches. Mines normal cable, my mate fitted a tilton peddle box so hydraulic clutch. A lot easier to drive with it being hydraulic, he hates driving my car. Would like to swap mine to hydraulic but I can’t drive with the peddle box, you need tiny feet so need to fine another solution.
Can't comment on the clutches but if I could rewind I'd definitely have done a hydraulic conversion when it was in bits
Right, that's me sold then. Keeps the door open if I want to move to try a JR5 box too as they use hydraulic.
I can see PMS do a kit for the gearbox end. I can combine that with the DCi pedal box, use the same AP racing master cylinder others have used and away it goes. Or is there a full parts bin conversion available using the entire DCi setup given I've got a DCi box of some flavour?
I dont think any of the jb/jc diesel boxes are hydraulic, all cable. If your doing hydraulic clutch, do the full lot inc jr box now.
Stop giving me more ideas man. All I wanted was a clutch, now I’m on a mission trying to work out how to get a JR in there 😂
Can you use a dci pedal box with the pms kit to make a jc5 hydraulic
Yeah, that looks to be the way. I’ve ordered a pedal box so will see what comes. I’ll need the PMS kit if staying JC box.
Pretty sure when I looked, the jr5 hydro release bearing setup looked like it would bolt to the input shaft sleeve bolts of a JC.
Ok so that’s an interesting option.
However, if JR5, which flavour did you use in the twingo? And can you get a decent clutch and diff for them? I’m not sure what they even come in to go on the hunt for the parts.
Am I also right in thinking the outer CVs are different splines to the Clio shafts?
I think if I seriously consider going for a JR5 box I’ll get a set twingo shafts and take them with mine to the driveshaft place near my work to see if they can work some magic and combine them. I’m not paying for custom shafts on something untested so if they can’t it’s dead in the water.
Good question was a while back now was a diesel box i went for though, all the petrol version were very short ratios and no good for a turbo lump. Yes all the joints are different to a clio so itd be a mix and match from twingo/modus and possibly clio cvs to get it all to work.
There are also different shifter types on the box end, both cable, but one is for a dash mounted shifter and one for floor mount, they are backwards to each other. I know this as i ended up with a dog leg first on my first go....
ill take read back and try to update, was about 5 years ago i built it from memory. The build thread is on turborenault if you fancy a read/search
not too sure on the diff, pretty sure there is though as its a JR5 fitted to the twingo rs from memory too.
Interesting. As always been interested in the idea of a hydro setup in case the Renault RHD clutch cable is discontinued. Always hear horror stories of the aftermarket items snapping.
Is the the P/N for the jr5 hydro release bearing 306206584R? (From the Twingo 2rs 133)
I fitted the sump tonight. My titanium bolts are beautiful. I was worried 25mm was too long but they all went in fine and they come out the other side anyway so could really use whatever. Thread size for the sump bolts is M7x1.0 for reference later. I might have gone a bit OTT with the gasket sealer but don’t care - I’m not doing all this to end up with a leaky sump. Interestingly I did fit 22 of them, despite there apparently only being 21 holes.
Then span the engine round which isn’t easy now it’s complete and weighs about the same as the moon.
The banjo water feeds for the turbo I got ages ago were a bit too long
Not any more
Then I spent ages messing with the orientation of the cold side trying to get the actuator close to the engine as possible for bulkhead clearance, but still far enough away so that the boost pipe isn’t sat on the exhaust manifold. Just about got there in the end and I think this should be fine. There’s a few MM clearance on all sides.
It did make me think though, I reckon the cleanest way is to have the boost pipe coming down off the turbo. My worry of doing it now is that I’ve got no idea what else it might hit. The driveshafts will be down there, I’m sure the ABS stuff is close by. It’s not something I can really attempt with it out the car and there’s not enough space to rotate the turbo with it in the car so it’s staying like that.
Also didn’t wear gloves or long sleeves when messing about so that heat wrap on the donwpipe has got my arms and hands itching like a crack whore’s fanny.
Adding to the list of ideal - tensioner came and it was for a 197 so that’s gone back. Pedal box arrived and despite asking twice, it’s for a cable clutch. Absolute divvies.
It does look quite pretty now at least.
A bit of alloy pipe welded onto the compressor housing, to extend the hsoe fitting, angled to clear the exhaust manifold would work and give you a little more room to move actuator.
I liberated a pedal box from a mk1 Kangoo. I admit, proper shite update but I had so much fun in the scrap yard. It was great being in one where you can just potter about and look at s**t then take off whatever you need.
Anyway, pedal box and master cylinder (which may or may not be of use) for £20 👌
Nothing too much exciting today.
I mock-fitted my new coolant hoses to make sure I’ve got everything I need. While I was on my thought it would be an idea to swap the bits from my old rad to new.
The old one really isn’t great. I got it 2nd hand during the turbo swap for next to nowt but it was much better than what was there.
I had planned to recycle the AC radiator but now I’ve stripped that off it’s fucked too so ordered a new one
There’s a crossover/join on the hoses to the heater matrix so that’ll be perfect for my coolant feed to the turbo. The pipes are stupidly long though, so I think they’ll need a trim before fitting properly.
I then spent ages pissing about removing the heater matrix connectors from the original hoses. Got there in the end with a bit of force.
And finally I’ve decided that I am a complete minge after all, and I’m not enough of a man to drive without PAS. I had a EPAS column to fit ages back and sold it because I couldn’t be arsed, but given I’m taking loads out to fit the hydraulic clutch and the access to the rubber bung is easy, I’m going to fit it while everything is out. Not doing controller - I’ll just wire it as per the povvo spec ones so it’s OEM style assistance. If it’s s**t then I’ll fiddle it to add a bit of weight.
I’ve also settled on gearbox setup. I’m going to fit the JC5-107 I’ve got sat in the garage and use a padel clutch with it converted to hydraulic setup. The original box managed about 6k post turbo before shitting its pants but it was never a good starting box. 2nd to 3rd was crunchy for a long time. The whine from the bearing that eventually failed had been there for a while. Theory is if it lasts the same 6k I’ve done well, 10k I’ll be buzzing.
Given I’ve got it, I don’t see the point messing about. I’ll fit it, see if I like it and see how it holds up. Plus it’s literally the world’s longest box so I end up with a theoretical 201mph top speed
Those two stubs for the heater matrix bypass need loads cutting off them, I think I shortened mine by at least 50%, pretty much just enough left to get the hose clamp on
Aye, they are stupidly long. But it’ll be a cracking spot to take the feed from without making a mess of the pipes
Just wired my EPAS up OEM and it works well imo. Will stick a write up of the wiring on the forum soon as there is no concise thread on the full working solution.
Great to hear and that’d be helpful. I’m happy with power/speed, just need to work on where to take the RPM. Any info is welcome 👍
Wiring up the epas as oem is absolutely the best solution. You wont get it better using the aftermarket shite kit.
@TheBandit be interesting to hear how you have got rpm on oem ecu, ive had a couple of ideas but not tried, as i skipped that on mine with simple wire into my ecumaster ecu for rpm.
That’s what I’m thinking.
From what I can see on the wiring diagrams, pin 70 on the ecu seems to take RPM, can maybe do something from the coil wiring and can also do something from the injectors. Although not entirely sure how I’d wangle that as it would record 1/2 the RPM.
Or I can take the “while I’m on” approach that has happened so far and f**k the standard ecu off for standalone and do it with much more ease 👍
