Clio 182 water in the footwell
  Clio 182
Well well, where do I begin? I've now had two Clios that have done the same thing! I know this has been posted before but there are no decent pics of where people should be looking for the drain holes (although their not to difficult to find). I've taken a couple of pics of where the one in the middle is as this seems to be the biggest problem!
I would however like to know that if all the drain holes are clean where else at the front of the car could water get into to?
Any suggestions would be great
DomP182
  ph1 172, Arctic182
My 182 will in a heavy rainstorm and if parked on a slope sideways with the drivers side uppermost leak a small amount through the drivers door seal. I park it facing the other way - problem solved!
Yours looks a whole lot worse than that though, reminds me of the sunroof in my 1.8 16v clio.
Have you checked the scuttle drains under the windscreen aren't blocked, our scenic has suffered this and it get through the dash to inside
Sent from my SM-G903F using Tapatalk
DomP182
  ph1 172, Arctic182
Oh by the way for that help you have to solve my issue now!
  Clio 182
I did think the door could be the issue but there is no sign of leaking from it when I prayed water over it. And what is your issue aha?
DomP182
  ph1 172, Arctic182
Look at the thread below yours by me.
  Clio 182
That's what iv pictured above? The center was blocked and I pushed a screwdriver through it to which water poured out. So I'm assuming I found the right place?
DomP182
  ph1 172, Arctic182
Jeahjthe dreaded limp mode
  Clio 182
Oh right! I just have one flap thing wasn't sure why they would put that on it? But the tune wasn't blocked it was the actual hole
