Clio 182 Wheelbase Length?
Not sure what the technical term actually it.
But does anyone know the actual length, from front of front wheel to rear of rear wheel please?
Clio 182, if it matters.
Cheers.
  182/RS2/ Turbo/Mk1
At what height? And with what size tyre?
By that I mean if for example you want to know in order to fit on a trailer, then the height of the bar that the wheel is going to butt up against will effect where on the arc of the tyre you need to measure to.
The wheelbase published is based on the centre point of the wheels. So from that you should be able to work it out.
Oh yeah I get your point, didn't think about that.
What wheelbase published? Couldn't find one when I had a quick look on Google.
Just trying to work out if a Clio could maybe squeeze on a 3.3 bed surface or whether the over hang would definitely be a no no.
Looking like it probably wouldn't at the minute but clutching onto straws.
  182/RS2/ Turbo/Mk1
Wheelbase is 2485 for a 182 IIRC (its more than a normal clio as the 182 has the increased caster arms)
You would certainly get the wheels comfortably onto a 3.3 meter trailer, as the wheel even at the futher point forward is only about 30cm or so (depending on tyre size) so from the front of the front tyre to the back of the rear tyre would still easily be within that, but it will depend on the height of the front and back of the trailer if there is enough space for the bodywork overhang.
I dont think you are going to be able to work it out exactly from numbers, you need to try it as your car could sit slightly higher or lower than someone elses which makes one of them clear the beam and the other not etc.
Wicked cheers guys.
The back there is no lip so over hang would be fine. There is a small lip at the front so that would need to be considered, but it only looks like a few inches.
Next step would be to test the car actually on it. I was just trying to work out if it's even worth the journey to look at for the time being :)
Assuming the car fits on the bed fine I'd just need to make sure the Clio is below the 1000kg limit, which shouldn't be a real problem I don't think.
  182/RS2/ Turbo/Mk1
Also need to think about how you are going to attach it if its sat right at the ends, can be awkward getting straps on etc.
But might just be a case of adding some extra anchor points.
