Clio 197 Engine Break In
Car  Clio 197 Red!
Hi guys, my first post here :)
Went to the dealer today and bought my dream car! A red one. Will have it after an agonizing weekly wait, so next friday I hope.
I asked the sales rep how to break in the engine since I found nothing mentioned in the car manual (its in Greek, is it the same with yours in the UK?). He said I'll find nothing in the manual since all I have to do is keep the revs just below the red line when the shift light comes on, for 4,500km (2800 miles), that simple. Have you guys been told the same? I know this is a controversial subject but out of curiosity how did you guys break in yours?
don't bother
as long as it's up to temperature (oil temp remember, not the water temp gauge) then i would drive it properly!
you should see the s**t new cars go through on final engine testing on EVERY car... you wouldn't bother running it in after seeing that!
:eek: its really bad... cold engine... never having been run before etc etc
I sh!t myself at Poxhall Luton & Ellesmere Port and watching the assembly from start to finish
lol
the friendly guys at the Greek import centre at the docks will have "run it in" for you anyway! :(
trashing it regularily (but not bouncing it off the limiter repeatedly) will ensure your engine is nice and loose early... and should get the best performance growth throughout the next 3yrs.
you should hope that as everyone else will be pootling around for the first 3k... yours could be nice and loose... and be one of the quickest std ones about
Thanx mate
I've also read its best to drive on twisty hilly roads so the engine constatly varies through loads, helps the gearbox too.
Christofer how can you tell when the oil temp is ready? Can only see readings for water temp and fuel on the dash.
Just let the car warm up for about 20 mins or so before giving it the beans, it'll be fine then.
^^yep. 15 to 20 mins does it.
the water temp on the dash is a false indicator really, that's why you'll get a soft limiter 500rpm lower until you're up to full temp
Thanx mate
not sure on that one mate
I read this in the manual as proper break in procedure for an Aprilia 1000cc bike I owned a few years ago and it kind of made sense since you should be varying the revs constantly and not just drive on a boring highway. Who knows with this engine though...
Anyway thanx for all your suggestinons guys.
Marino
Don't listen to the whole "keep it under certain revs".
If you want a fast car, I'd take it from the dealers to the track the same day (and don't drop below 100 on the motorways).
Think of it this way, you make the engine think it's only ever going to do 3000rpm, when it's done 1000 boring miles like that, what's changed???
On the other hand, you show it what being an engine's all about;)
it doesn't have feelings... its just an engine lol.... you talk to your car don't you
Only speed up.
p.s. I have just watched the Matrix trilogy so that might be some part of the last post (reloaded and revolutions all the way through for the first time... AMAZING!)
