Hi there, new to the forum but I’m just after a little advice if possible as no one local to me can understand what could be going on with the reverse selection in my Clio 197!
So, a bit of a random one but I've recently purchased a Clio 197 which is an amazingly fun piece of kit, but every now and then I can't engage last gear... It's not as if it's trying to get in and grinding or anything and when it does decide to select reverse it's absolutely fine as if there is no issue. All forward gears are perfect and it has had a new box under warranty 20k ago with a new clutch to match. I have a KTR induction kit fitted at the moment and the most recent mechanic seems to think that maybe that is interfering with the selector cables...
It is like the selector is completely blocked off going in to reverse, although it has done it after normal driving, it seems to happen more often after a slightly more spirited run. By lifting the collar, the gear stick moves across as it should but just won't slide up in to reverse gear no matter how hard you try and force it… As the box does seem fine, I’m convinced it’s a worn linkage bush or something along those lines. No one I have spoken to has come across this in the past and there is no forum threads at all!
Can anyone help?
Cheers!
Can anyone help?
