Clio 200 clunking when cold
Car  clio 200 cup
My Clio 200 cup is making a clunking noise when driving along and let of the accelerator, it only happens when the car is cold and at very low speeds! Im pretty sure the noise is coming from the drivers side at the front.
Anybody got any ideas? not had a look underneath yet!
Would be the engine mount next to your oil filler, common problem in these. See if you can move the mount side to side with your hands.
Thanks for that I will have a look this weekend are they pretty easy to replace?
Seemed strange only does it when cold!
Not sure tbh, I have it on mine but I'm upgrading to some vibra technics mounts. With all 3 on you don't even need that top one.
I have just had it up on the ramp, the only one that there is any movement in is the top stabilising mount it only moves a tiny amount but should it be solid?
