CLIO Iceberg 172
right more on this:
over the weekend iv been experimenting with various standard air box configurations
so far this is what iv found, using a standard 172 airbox with a KTR panel filter and standard inlet elbow, and an outside air temperature of 15 degrees C and an engine coolent temperature of 86 degrees
no CAF: inlet temperature ranges from 68-78 degrees C, car feels very sluggish in every gear, big lag gap with foot planted,
standard CAF: inlet temperature ranges from 58-64 degrees C, car feels back to normal, pulls nicely but still has a slight gap with foot planted,
at this point i took the plunge and bored a 83mm hole into the original main inlet hole on the airbox, from here i fixed a 80 x 30mm pipe to give my self something to mount onto,
from there i attached a 80mm silver ducting CAF, this was ran down to the original area of the existing CAF but approx 8" lower just past the horn, but not replacing the fog light.
and also removed the plastic cover from the engine as i felt this could potentiality hold a lot of heat in.
uprated CAF: inlet temperature ranges from 38-54 degress C, car feels very responsive, pulls very well in all gears compaired to standard CAF, almost eliminated any lag from foot being planted,
so there you have it, with an uprated 80mm CAF and removing the engine cover, iv managed to get the inlet manifold tempuratures down by 20 degrees, all tempuratures where taken on the fly via the OBD2 port using a laptop to monitor, engine coolent tempurature, manifold pressure, engine revs, inlet manifold tempurature, and throttle position sensor,
the softwhere was proscan 5.5 registered version
i dont know how this translates onto a rolling road, but i do have a benchmark RR from the east angla RR day where the standard airbox with standard CAF made 162.1bhp and 141lb torque
i shall try and get some comparison charts made from the data i collected
and also some pictures of the set up so that it might help people in the future.
Dave
Dave
