Clio dci running problems
  Revels Mum & Sister
After some advice for a female friend
She has a Clio dci 80. Recently it has been running rough and smoking (Sooty) she took it to a garage who have said the fuel pump is knackered however they have told her they 'adjusted' it which I believe isnt possible. Also it is running a little less Smokey however apparently has a fuel leak somewhere...
This to me does not sound like a pump however can someone confirm? Or perhaps try some things we could try!!
  Revels Mum & Sister
Hmm good thinking would explain the poor running (If it has one!) however not the fuel leak
  DON'T SEND ME PM'S!!
EGR valves and the J pipe from them get very clogged up.
Cambelt timing is worth checking and this controls the pump too
  Revels Mum & Sister
I saw some teeth on the Pump so good shout. Checked a guide for EGR valve as well. Quick job and worth a crack.
Good shout on the filter. Unless the pump itself is leaking. Being a women it is like cracking code
