Clio Ecu
think its under the jack m8.....u might need 2 take sum panles off once the jacks out....not exactly sure though, shud disconnect quite easily
Open the bonnet, put the support bar up and then walk round and stand on the drivers side of the engine bay.
Under the flappy bit at the bottom of the windscreen you have the jack and, under that, is the ecu.
And it's a b!tch to get to... LoL
Have you got a haynes manual? The best thing to do is take the wiper off and then the plastic cover that's under it, as it gives you a bigger opening to work with!
