Clio key Case (FOB)
whats wrong with the case? everything looks fine here, or is this key not unlocking your car?
The case is not closing well, every time i change the battery i need to close with a zip tie.
Ita anoyning me.
Any help will be greatful.
Daniel.
well these key fob's have grooves to slot each side into, so perhaps try putting a small amount of bluetac in the groove, maybe that would secure it better?
just an idea.
I will try it thanks, on ebay i found only the case without the holes, maybe other renault share the same key?
the key you have is IR like you say, the other key types your seeing are probably looking like this, and they are not IR but radio i do believe.
radio key.
IR key
This is the only i found but its used, i sended a massage to the seller to ask the condition if the plastic.
