Clio Mk 1 Door Trim Removal
Car  Clio Mk 1
How do you remove the interior door trim from the front and back doors as i my central locking is not working correctly so i think it needs lubricating?
Matt
Just undo the handles, door pull and bottom shelf thingy then the panel should just pull off. If its never been taken off before itll be stuck with loads of cr*p so just take your time :)
are you meaning the bit you wind down the window with if so, just pull it.
youll need some torx bits to remove screws, half the handle will pull off, 2 screws behind it.
3 on bottom pocket thing, one in divider of pocket. one in door opener handle. once youve got all that off, pull it off gently from bottom, use constant force, its stuck on with some mastic type shyte thats a pain.
