Clio MK1 Will i be able to fit a rev counter?
Car  172
I have a MK1 Clio '95 1.2, i wanted to get a rev counter with a pod. How do i fit this, is there a wire that goes somewhere on the coil pack?
all i have done mate is fit the speedo from a 1.4 into mine and am yet to no whether it all works as im just putting back together my engine after fixing the head gasket
Thats the problem, i don't have a rev counter in there as standard. I have bought a 52mm guage and i'm not sure how to fit it?
i've got a 1.2 ph3, the revcounter and the speedo work, the thermostat doesn't work, and i haven't checked the petrol gauge yet, but it should work fine. I have a spare set of the main dials lying around if your interested in purchasing a set ;)
i will take a few snaps for you when i change over my clocks, should be in the next few weeks once my exams are all clear. Drop me a pm every now and again so i dont forget as i probably will.
Thanks an02rew!
I'm not changing my clocks over, i have bought a separate rev counter. I'm not sure how to connect it to my coil pack?
