Clio MK2 1.4 16v problems
Car  Clio MK2 1.4 16v
Recently, I bought a Clio in Greece getting ready for moving back there in Dec. I have a few problems that i would like to sort out.
Problem 1: While playing with climate control, the temperature numbers dissappeared and i do not have a clue what i did or how to mend it.
Problem 2:There is a buzzing noise when the ignition is on.
Solution: I believe the solution is to clean up the fan inside the roof console?
Problem 3: The engine sometimes does not start first time when engine is a bit hot.
Solution: Change coolant temperature sensor?
Problem 4: Engine is not idling properly sometimes. It will be ok and after a while, it will start playing up from 500 to 1000rpm.
Solution: Changed the O ring between inlet manifold and throttle. Made it a bit better but hasn't solved it. (Could the slight exhaust leak between manifold and downpipe cause it?)
Help me plzzzzzzzz
