Clio Mk2 1.6
Hey guys
Looking for some info and ghope you guys can help out
Is the Clio 1600 engine the same as the one in the Megane and Laguna?
block and engine mount wise?
We are developing an interesting project for 2009
Yep sort of if you strip them down to that level.
Angelworkds are doing some development work on a 1.6 at the moment.
Don't forget there are a laod of versions realy with VVT or noe and manaul bodies but at block level its ok realy.
Engine wise yes, mount wise pass. Its a K4M 744 in the Ph2/3 Clio, would imagine its a different revision number with the Ph1 being cable throttle same with the Megane and Laguna.
