clio mk2 ph2 electric sunroof
Car  renault clio 2003
Hi guys im new on here i have a problem i have 2003 clio 1.5 dci with electric sunroof when i drive local its fine but when i reach high speeds such as 80mph or 100mph the windscreen rattles like its gone smash any ideas? on how i can fix it? thanks
it rattles or there is just a buzzing coming through it?
if it rattles I wouldn't really be driving it....
if its buzzing,
its normally just wind getting through the window seals,
so just seal it up with silicone or tiger seal:)
sunroof or windscreen? kind of confused as to which you are on about? if its the windscreen, i would'nt even drive until someone checks it. if its the sunroof then sounds like your seals have gone.
Probably had a new screen at some point and sounds like they haven't primed the glass fully before fitting and the bond won't of worked properly. If it is actually loose then I wouldn't drive it and call a screen company to remove/refit expect to pay about £75ish but there is a chance on removal that existing screen could crack!
EDIT: As said above I wasn't 100% which you meant so I presumed windscreen!
