new to the forum had a few clios now, just got a mk1 rsi
planning to modify it keep it factory looking oem+1 is my over all goal.
so far had to spend a wee bit getting it good.
timing belt and tensioners done,
new aux drive belts
replaced all the brake lines
2 new wheel bearings
1 new track rod end.
overhauled rear calipers
had to replace one of the exhaust valves and do the tappets replacing shims etc.
new aluminium radiator
R5 GT Turbo fan
scopion decat
full stainless steel cat back exhaust 2.5 inch tail pipe (just fitted tonight)
bosch super 4 plugs silver tipped
new ht leads and coil pack.
new fuel filter
need to get a new coloumn too much play at the EJ bush
plans.
MK1 pH2 spoiler
colour code the blacks (NAPLES RED)
megane coupe front factory strut brace with strut cover (already colour coded)
R21 turbo green injectors
fse in tank pump
fse power boost valve.
8.5 ignition leads.
custom closed air induction kit using factory airbox and front vent in bumper grille.
lowered 30mm on spax vsx kit
torsion bar lowered to suit
all front poly bushes including dogbone mount.
eibach camber bolts.(front)
original rsi alloys powder coated white with genuine speedline centre caps and decals
grooved discs all round
front brembo pads
rear omp pads
goodridge hoses all round
16v steering wheel with custom centre
colour coded intereior
custom rear badges using renault sport wing badges
16v or williams front bumper with custom factory hex plastic mesh.
falken sport tyres all round
redtop battery
omp rear brace if i cant source a 2nd hand one.
rolling road tuned and remapped and geometery to be set up by company in fife, scotland.
I will add pics soon hope to get some videos of the mods being done as i will be doing most of them by myself.
what do yous think
new aux drive belts
R5 GT Turbo fan
scopion decat
new fuel filter
plans.
MK1 pH2 spoiler
fse in tank pump
8.5 ignition leads.
front brembo pads
rear omp pads
redtop battery
what do yous think
