thought i was clkever today and decided to steam clean the engine, then the propblems started!
first off all the car just revved to 3k and stayed there then dropped down then wenet up then when you put your foot hard down it only revs to 3.5k, tried aligning the throttle body with the ignition off and tried fooling the car into thinking the butterfly was in a different position and then it would be ok for the first blip of the throttle but after that it will only open less than a quarter and allow the car to rev to 3k
plugged in a code reader and it said throttle potentiometer fault, now i have read on here and seen the throttle body is a comin fault but surely its a bit of a coincidence to only play up when it was washed???
i have since sprayed wd40 contact cleaned and dried pretty much every connection that got wet, reset the eml and disconnected the battery and had no joy, i have even got to the point where i thought that the throttle body must be nackered so thought there was no harm in opening it up and seeing if it was wet and then cleaned it but its still no good
my question therefore is what breaks on the throttle body or has anyone else had the same problem or what do you think the fault is?
maybe if i leave it all to dry over night it might sort itself out but i really did not think the electrice were that shocking on these...i didnt even directly spray any plugs!!!
note to self...do not steam clean the engine bay on a french car again!!!
